Question about android phones
Go to solution Solved by minibois,
so about that LG G2 i was watching a review about one and a lot of people say that the custom LG android os on it isn't that great and is hard to get around
I dont really like the LG Android stuff on my LG phone.
It shouldn't be hard to get around though.. Just install a custom rom
In theory: yes.
You would have to get that Android OS though, which shouldn't be too hard since Android is a free OS
Either download the OS from the web or try to factory reset the phone.
But why change to stock android again? :3
Current Build Logs : ~ "The Future is Back" ~ "NES, The Little Beast" ~
z170l || i5-6600k || Noctua something cooler || 2x16gb ddr4 || msi 1050ti superlowprofile || hdplex 260w psu
oh I thought by stock you meant factory stock
go with cyanogenmod
