need help updating MSI bios
Solved by LogicalDrm,
thanks for the welcome, the thing is they aren't specific on what to do after the bios update so that's why i'm here.
If you have done something in BIOS settings, you will need to redo it after update. Updating will reset settings. So things like boot order, OC and disabling several devices or changing fan settings will be back to default. If your boot order is correct by default then you can let it go to windows.
