What is the best type of clothing material for working with computers, Polyester or Cotton(electricity wise)?
Thanks,
-Shadow
no clothing is the best,
ive never had a problem with cloths as long as you have something nearby to discharge every once and a while,
i just use my watch as an anti static wrist band
Ceramic is one of the best as far as price/performance.
Answering... ground yourself every few minutes.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
It doesnt matter because then you work on a computer it should be OFF
i would assume he means for static
cause some clothing builds up lots of static
high electrical resistance is what causes static electricity...so that wouldn't make sense because hes asking for an insulating matterial
I do ground myself every few minutes, however, I like to keep the possibility as low as possible that I'll destroy my $100 CPU. Just wanted to know which one is better for reducing my chances of killing something off.
get a watch xD, so when ever your overcharged it will buzz the watch
its how i describe it
i build a lot of static electricity up through out the day, every hour to 2 hours i can feel my hand shock my watch,
The watch isn't grounded, anyway.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
