Titan X questions
Go to solution Solved by Najuno,
Considering Titan X:
1. I have read that the TX is the full GM200 chip.  Is this true and not like the original Titan that was not fully unlocked and then unlocked with the Titan Black/780Ti .  What I really hated with the 700 series is that I bought a 780 and thought it was great and a little later they released the 780ti for just $50 more than I paid for the 780 and the ti was fully unlocked.  That and with the pricing drop I felt I essentially lost $150 .
2. With such a high VRAM amount would the Titan X run out of processing power before it uses all the memory (in the next 3 years for games). i.e. Is NVIDIA correct for some future proofing with the VRAM.
Coming from a single GTX 780 would the TX be a good upgrade?  Considering since it seems games are now asking for more VRAM and getting 12 GB and being done with it seems better than just buying the cards every year that seem to just give you enough to stay just ahead of the games.  Am waiting to see the prices for the Acer 3440x1440p curved G-sync and 2560x1440p monitors and the TX might be good for them.
1. Titan X features an full GM200 chip.
2. There´s no such word as future proof in PC hardware but a Titan X will give you good performance for a long while.
3. A Titan X upgrade from a GTX780 would be a hard upgrade because more than twice the performance.
CPU i7 4790 | Motherboard  ASUS Z97 Maximus Hero VII | RAM 16 GB Trident X @ 2400 Mhz | GPU Titan X | Case NZXT Phantom 530 | Storage Samsung EVO 840 1 TB SSD, 2 Seagate 150 GB HDD, 1 External 3 GB Seagate HDD | PSU Corsair HX 1050 | Cooling Zalman Copper 2 ball | Keyboard  Logitech G710+ | Mouse Logitech G502 | Sound: Creative Z | Operating System  Windows 10
https://linustechtips.com/topic/330584-titan-x-questions/
1) the 780 ti came  out quite awhile after the 780, so it wasn't a real issue. The titan black is fully unlocked, but that doesn't matter in the first place, they probably won't have any better cards for a year or more.
2) For gaming the vram is excessive, but that also means you won't ever need to think about it.
The titan x should be quite a bit faster than the 780, I think around twice as fast, as well as having the extra vram.
https://linustechtips.com/topic/330584-titan-x-questions/#findComment-4488261
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/330584-titan-x-questions/#findComment-4488262
I have a Corsair HX1050 PSU.  I'm assuming it would handle any overclock on the TX fine.
https://linustechtips.com/topic/330584-titan-x-questions/#findComment-4488707
Yes but of course this PSU would even handle a Titan X 2way SLI :).
https://linustechtips.com/topic/330584-titan-x-questions/#findComment-4488778
Thanks.  Just thinking ahead.
https://linustechtips.com/topic/330584-titan-x-questions/#findComment-4495878
