Small Amp
Solved by dylan43270,
So my only concern now is that the sub itself has an amp in it, and that's how it plays the lower frequencies? Right? And the output would then also be amped and sent to an amp and be amped again before going to the speakers. Or does the subwoofer act more like, computer speakers, like, it doesn't amp it, its just able to read and use those lower amped(?) Signals?
The sub I posted is run by itself at 80w. running the speaker wire to it and back out does not power it or take power, it just transfers the signal so that you can crossover the bass.
