Hello LTTF
     I need the advise of our resident audio files on LTT fourms. I am trying to put together a cost effective headset for my up coming build, the SteelSeries 3H V2 just isn't holding up.  This is what I have so far.
Headphones: Sennheiser HD 449 Headphones  ($54.00 @ Adorama)
Other: ModMic (version 4.0)  ($49.95)
Total: $103.95
Generated by PCPartPicker 2015-03-14 22:53 EDT-0400
Thank you for your help, and time.
https://linustechtips.com/topic/328382-entry-level-headset/
I would get sennheiser 518 and a zalman mic, it will sound MUCH better to you and the zalamn mic is actually pretty good.
https://linustechtips.com/topic/328382-entry-level-headset/#findComment-4458077
Have a look into the Audio Technica PDG1's, they 'retail' at $199USD but you can get them for about $180AUD so if you take the Australia tax and currency conversion into account they should run a similar price to your option in the OP and they are honestly blowing my mind with the price/performance and actually great audio from a headset compared to a headphone/modmic combo
https://linustechtips.com/topic/328382-entry-level-headset/#findComment-4458088
What mic are you referring to?
This one, I don't think they sell any other ones.
https://linustechtips.com/topic/328382-entry-level-headset/#findComment-4458118
Do you want a headset or headphones?
cause there is a difference.
Cpu:
Intel i5 4460 Motherboard:Msi Z97S Sli krait Ram:HyperX Fury White (2x4) Storage:Seagate 1tb/Samsung 850 Evo 120gb Gpu:Gtx 960 2gb sc Case:S340 Black Psu:Corsair Rm 650w 80+ Gold certified
My anime list : http://myanimelist.net/animelist/KRImSIN
https://linustechtips.com/topic/328382-entry-level-headset/#findComment-4458128
Basically all other headsets are either garbage, overpriced, or overpriced garbage.
Plantronics RIG aint garbage but have a few quirks, and aren't overpriced if you're a console pleb due to the mixer.
Cloud doesn't have any "buts" though.
https://linustechtips.com/topic/328382-entry-level-headset/#findComment-4458627
