Hey i saw this ad and was wondering is it possible to easily fix this?
http://www.expatriates.com/cls/26736788.html
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/327920-m7-pink-tint-issue/
Ask the seller if it's running CM12. The latest nightly builds have had a problem with tinting the screen, due to the implementation of Live Display.
If it is running CM12, you can either wait untill the problem is fixed, or revert back to an earlier build.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452802
My stock M7 has the same issue. It's a hardware problem as far as I know. It's the censor that controls focus which is overheating / defective. Something like that atleast.
I've seen various fixes, but I've never actually had the luck to fix it myself.
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452811
I would call HTC, if that was my phone. They find they need to fix issues like that for free.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452817
I guess it's better,if  I don't look into it i guess
ExSystems
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452822
Looks interesting, but I have no clue.
Since it happened after a software update, you might be able to flash back to an earlier version and find it working fine, or find that it's permanently damaged.
I don't want to take the risk....
ExSystems
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452825
If it is running CM12, you can either wait until the problem is fixed, or revert back to an earlier build.
Isn't that a custom Rom?
ExSystems
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452840
It is, but judging from the pictures, it doesn't look like the phone runs HTC Sense anymore.
And if the custome rom is CM12, than that might very well be the problem.
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452844
It's not something that's always there. It's mostly if it's a darker setting
Here's a picture of my keyboard, where you can see the tint is very visible: http://i.imgur.com/vdMsbEl.jpg
If it's outside with even some tiny amount of daylight, then it's all good... Atleast for me :)
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452849
If I was to resell it,It would also cause me problems
and eeeeeeeh that purple makes me horrified for some reason,like the camera will die out or something
ExSystems
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452860
Yep it most likely would.
Tried calling to ask him,if he is running cyanogen mod but won't pick up i guess it's best if i stay away
ExSystems
https://linustechtips.com/topic/327920-m7-pink-tint-issue/#findComment-4452875
