Hey, for some reason whenever I lift my Deathadder off the mousepad, put it back down and move it, there is a delay where the pointer won't move for a bit.  This is VERY annoying in games, especially fps because I am constantly looking around and my mouse pad isn't very big.  If someone could help, that would be great.
https://linustechtips.com/topic/327732-razer-deathadder-problems/
How long have you had it. This actually happens frequently with Razer mouse. Not just the deathadder. My friend just bought a new mouse yesterday since he had the mmo Razer mouse for 4 years. My other friend got a new one since the same thing happened, but he had it for a shorter time.
Sometimes the mouse wouldn't move so he had to shake it vigorously till it moved while sniping in counter strike haha. But ya. Could be meaning you mouse is close to kicking the bucket. But if it's new, you got a warranty? If not, maybe there is a fix somewhere.
- Fresher than a fruit salad.
@LtRavens I literally just got the mouse.  Been using it for a few days.  Sucks cause I've heard it's a very reliable mouse and that's why I bought it.  Razer has left a bad taste in my mouth now, so I will probably not buy the Deathstalker keyboard like I was planning.  Any mechanical keyboards you recommend?  I've been looking towards Corsair
I would agree with you going with Corsair. But there are plenty of keyboards you can check out. I can only speak for their K70s, which are great. Unless you want macros you can go to the K95.
Sorry for that inconvenience. Razer is a mixed bag. I heard the keyboards where pretty good. But I never had one personally.
