2nd round of peer review
Solved by Tithonius,
Not sure where on the Nzxt web site you saw that it should work. The compatibility checker on the G10 web page reports
"UNKNOWN The MSI GeForce GTX 970 4GB Twin Frozr V Video Card and NZXT G10 Video Card Cooler compatibility could not be evaluated.
Compability Notes:
MSI GeForce GTX 970 4GB Twin Frozr V Video Card support for the non-reference PCB on the NZXT G10 Video Card Cooler could not be verified. Fit will depend on PCB component and mounting hole mounting layout."
I believe EVGA 04G-P4-2972-KR is compatible with the G10.
Okay, thanks for the input, its nice to catch things like this now and not later in the build
