Help, assignment.
Go to solution Solved by QueenDemetria,
A School, using a Wireless-N compatible laptop.
There is still too many variables, like AP and wifi card, placement of the AP, and density/construction of the the walls(and amount of walls in the way). In general though it will have shorter range and poorer wall penetration than 2.4Ghz, but it won't be on a crowded frequency like 2.4Ghz(for now). There really isn't an exact answer sadly.
I'm currently doing my assignment, I would like to know what is the distance of 5ghz wireless? before you cannot connect to it no more.
Thanks. :)
https://linustechtips.com/topic/326695-help-assignment/
Thanks. :)
Depends on the piece of technology, some range from 1m-20m? In what instance tho.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/326695-help-assignment/#findComment-4437371
depends on the response of your aerials and how much power you want to broadcast with. 5Ghz isn't a complete standard like bluetooth is.
There are too many variables with that question. Can you clarify the environment and hardware?
https://linustechtips.com/topic/326695-help-assignment/#findComment-4437407
The only real answer I can give you is that a signal broadcast on 5 Ghz will have less range than a comparable signal on the 2.4 Ghz band. What it will do better though is penetrate objects better between the sending unit, and the reciever with less signal degradation.
https://linustechtips.com/topic/326695-help-assignment/#findComment-4437409
https://linustechtips.com/topic/326695-help-assignment/#findComment-4437514
Okay. Thanks for you help :)
Ill ask my teacher.
https://linustechtips.com/topic/326695-help-assignment/#findComment-4437520
