My friend wants to play minecraft at 30fps and record. the budget is ass close to $500 as possible and around $200 for
peripherals.
30 fps in minecraft doesn't take much. Maybe he should go with an APU do to his low budget.
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/32663-friends-build-help/#findComment-417627
This is just off by $9 but remove the SSD and its certainly a lot cheaper I would also like to add this will push Minecraft a lot further than 30 FPS if he wants a system for 30 FPS specially he would need to buy an older system anyway most integrated graphics solutions run at over 30 FPS now on MC.
http://pcpartpicker.com/p/1dnf6
https://linustechtips.com/topic/32663-friends-build-help/#findComment-417671
k,thanks
https://linustechtips.com/topic/32663-friends-build-help/#findComment-418150
https://linustechtips.com/topic/32663-friends-build-help/#findComment-418794
