Test Surface
Go to solution Solved by Tro,
So I can just take any cardboard box and use it as a test surface?
Yep, no problem.
I bought this mobo of a friend and he didn't give me a box
Any kind of cardboard or foam should work.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/325807-test-surface/#findComment-4425141
Yep, no problem.
https://linustechtips.com/topic/325807-test-surface/#findComment-4425153
The glass will not conduct but you may well scratch it with the 'jaggies' on the bottom of the MoBo.  Or you could bend/break something on the base of the MoBo by placing it on the glass.
Best to use something with a bit give in it like a sheet of cardboard(probably the cheapest and easiest solution) or a sheet of foam or even a piece of wood (preferably soft [like the, strangely, a hard wood :Balsa]).
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/325807-test-surface/#findComment-4425294
