Hej
recently i showed off my rig here: http://linustechtips.com/main/topic/324881-console-peasant-build/#entry4412605
So now i upgraded to an i7 4790k, i installed it correctly and started to play Battlefield 4 i noticed  that while playing the temps go
up to 80c but im idling at 30-40c.
So my question is are those temps normal? I didnt overlock the cpu its running at stock 4.0Ghz.
You can find my cpu cooler here: http://www.scythe-eu.com/en/products/cpu-cooler/mugen-4.html
thanks for your help!
https://linustechtips.com/topic/325695-i7-4790k-temps/
Hej
That seems very normal.
https://linustechtips.com/topic/325695-i7-4790k-temps/#findComment-4423681
Hej
-snip-
temps are ok dont worry if its 80c.it depends on room temp,case airflow,etc....You can check if cooler sit well on a cpu or maybe if you applied too much thermal compund,or too little if you builded pc yourself.
hope i helped(and that you understood me(not a native english speaker)).
edit:my bad did not see the config.nevermind the airflow
https://linustechtips.com/topic/325695-i7-4790k-temps/#findComment-4423714
r9 290's are causing case temps to rise alot, but those temps seem more in line with a stock intel cooler. did you put the right amount of thermal compound on and clean off the old? also is the cooler correctly installed?
Your GPU temps won't affect your CPU temps.
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
https://linustechtips.com/topic/325695-i7-4790k-temps/#findComment-4423716
Ohh then something its wrong with my cpu because i didnt overlock it :( Its a expensive cpu i cant afford another one now :(
what are your fan speeds
will you trade my 212 evo for that thing?
https://linustechtips.com/topic/325695-i7-4790k-temps/#findComment-4423781
  1. return merchandise authorization (RMA), return authorization (RA) or return goods authorization (RGA) is a part of the process of returning a product in order to receive a refund, replacement, or repair during the product's warranty period.
source: google
https://linustechtips.com/topic/325695-i7-4790k-temps/#findComment-4423805
source: google
Thanks
Im not trading or selling the cpu that i buyed today :) just want to fix it somehow :)
https://linustechtips.com/topic/325695-i7-4790k-temps/#findComment-4423809
