Ok so when i first booted today i found out that my pc couldn't find the hdd. I restarted and it was fine, or so i thought. Later on while playing boarderlands 2 it randomly shut off and then came back on so i continued to play and then it did it again. So i scanned for viruses using norton and nothing was found, i check the cpu and gpu temps while under-load and everything looked fine. But when playing a game it would take forever to load and was very laggy with major lag spikes. I uninstalled norton and restarted again and now everything seems fine again. I am very nervous and confused, someone please help!
I run my own indie game company called Color Dragon Studios where we are currently making a 2d platformer game called Small Earth.
https://linustechtips.com/topic/325337-possible-hdd-issue/
lol dont use norton
use malwarebytes and either AVG or avast (free versions)
use crystaldiskinfo to check your HDD health
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4418718
lol dont use norton
Do you think that it is possible that norton caused this? Also i got avast about a week ago and it caused it to blue screen, i pretty sure that was due to having norton and windows security essentals already downloaded and being used. Also where can i safely download crystaldiskinfo?
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4418742
idk but norton is just bad, dont use it at all
http://crystalmark.info/software/CrystalDiskInfo/index-e.html
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4418933
Alright, i will stay away for now on, thanks for the link too by the way.
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4419008
youre welcome :)
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4419039
You can only reliably run 1 AV at a time, Norton will BSOD if you try to install anything else while its running. WSE auto-disables itself if it detects something else installed.
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4421070
maby its PSU problem what psu you have?
and use malware-bytes not norton,norton is just crapware
CPU:Intel Pentium G3258 OC 4,5 GHZ GPU:Zotac Geforce GTX 960 RAM:PNY 1x8GB HDD/SSD:1 TB Hitachi HDD/64 GB A-Data SSD Phone:Lumia 520 Laptop:Acer Aspire v3-531g/pentium b980 gtx 630m 4gb ram(rip acer aspire v3-531g harddrive failure + melted gpu;( )
CASE:Cheap Noname case PSU:Corsair Builder 430W Monitor:Acer 1920x1080 5ms OS:Windows 1.0
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4421780
I have a corsair cx750m and it is less than a year old, i some what hope it is because i wouldn't mind picking up a evga fully modular one :)
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4424264
do you have like old case or somthin? it may be your powerbutton problem
https://linustechtips.com/topic/325337-possible-hdd-issue/#findComment-4448100
