Sims 4 Not Starting Up
Go to solution Solved by snoopy6489,
I'm posting this so if any one else has this problem. If you are running the beta version of origin uninstall it and re install it and don't enable use the beta version of origin. That made it work for me.
Hello
I went to play the Sims 4 and it keeps telling me that My gpu is not supported. I was playing it no problem about a week or two ago. I have tried re installing but it did not work. My gpu is a Nvidia Geforce GT 750M. I have attached a picture of the error and my DxDiag info.
Thanks.
post-52936-0-96407800-1425857743_thumb.p
DxDiag.txt
https://linustechtips.com/topic/324666-sims-4-not-starting-up/
geforce experience is a tool you use for updating your drivers.
reinstalling gforce experience when you want to backdate your driver is like getting your screw driver repaired when you want to fix a table
follow the instructions here to backdate your driver
https://linustechtips.com/topic/324666-sims-4-not-starting-up/#findComment-4410101
I think this is on EA's end. Looks like what happend with cod ghost's on the pc when you used less than 6gb ram. It was a total bs issue
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/324666-sims-4-not-starting-up/#findComment-4410102
Set your post as being the "Answer", then. That way people will know that you managed to fix it.
https://linustechtips.com/topic/324666-sims-4-not-starting-up/#findComment-4417908
