I read a review on asus z77 sabertooth lga 1155 motherboard and the guy said when installing the evo he recommended low profile ram. Is that a requirement or just a recommendation? I myself am leaning more towards an ASUS p8z77-v pro. Would that be the same recommendation? I don't want to get low profile if I don't particularly need it.
https://linustechtips.com/topic/32448-cooler-master-hyper-212-evo/
Yeah I was wondering this too; will corsair vengeance work?
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
The cooler with the fan hang over DIMM slots. You'll need low profile RAM for the slot closest to the socket.
Unless you're using all 4 RAM slots you can use high profile rams. If you're only using 2 sticks then you can use the slots that is the farthest away and it won't interfere with the fan.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
Thank you, I will just be using 2x4gb sticks (for now)
I have Vengeance RAM on a Z77 mobo with a 212 and it doesn't hit on the furthest RAM slots. 'Low profile' in this case really means regular RAM without silly heatsinks on it. The other Vengeance model with the small heasinks will work in all slots.
Laptop Lenovo Thinkpad X220 - CPU: i5 2420m - RAM: 8gb - SSD: Samsung 830 - IPS screen Peripherals Monitor: Dell U2713HM - KB: Ducky shine w/PBT (MX Blue) - Mouse: Corsair M60
Audio Beyerdynamic DT990pro headphones - Audioengine D1 DAC/AMP - Swan D1080-IV speakers
so the only difference is the gigantic heatsinks? More for something to show off? That's good to know :)
That's the only difference  :) RAM spec really doesn't matter as long as it's DDR3 1333mhz or higher.
Thank you. I appreciate that.
It depends a lot on your mobo and depends how you want to orientate it. I barely fit mine horizontally sacrificing one RAM slot but that was all :)
you're using 3 ram slots? 12gb?
Nice, are you using a Noctua fan?
My PC specs; Processor: Intel i5 2500K @4.6GHz, Graphics card: Sapphire AMD R9 Nano 4GB DD Overclocked @1050MHz Core and 550 MHz Memory. Hard Drives: 500GB Seagate Barracuda 7200 RPM, 2TB Western Digital Green Drive, Motherboard: Asus P8Z77-V , Power Supply: OCZ ZS series 750W 80+ Bronze certified, Case: NZXT S340, Memory: Corsair Vengance series Ram, Dual Channel kit @ 1866 Mhz, 10-11-10-30 Timings, 4x4 GB DIMMs. Cooler: CoolerMaster Seidon 240V
yes.
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
