HELP!
Solved by slightlyjaded,
do i use 2 of them and leave the +2 part out of it, as there not fitting trying to put the +2 part in?
first time pc build!
The +2 is to fit an 8 pin plug. I just have mine tucked through the cables to tidy them up.
From memory 970 uses 2x6 pin plugs.
kerriya ·
Posted in Cases and Mods3 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
Ha-Satan ·
Posted in Networking3
play_circle_filled
Latest From ShortCircuit:
