pc build help
Go to solution Solved by Guest,
I would stick with Z97.
If you want GTX 980 SLI then you want a 1440p or 4K screen to make the most of it.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($109.98 @ NCIX US)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Memory: Kingston Savage 16GB (2 x 8GB) DDR3-2133 Memory  ($121.99 @ Amazon)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card (2-Way SLI)  ($549.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($139.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $2288.87
Generated by PCPartPicker 2015-03-15 08:22 EDT-0400
I am sorry if i am putting this post in not the right place butt i need help build a gameing pc i can have $1700 to spend on it i have some HDD here so i don't need any .any in putt wold help a lot
Corsair HX750i High Performance Power Supply ATX12V/EPS12V 750 CP-9020072-NA.$147
MSI ATX DDR3 2133 Motherboard 970 GAMING$104
Microsoft Windows 8.1$107
ASUS PCI-Express x1 Sound Card XONAR ESSENCE STX/90-YAA0C0-0UAN00Z$179
Sapphire Radeon VAPOR-X R9 290X 8GB GDDR5 DUAL DVI-D/HDMI/DP TRI-X PCI-Express Graphics Card 11226-11-40G$500
AMD FX 9590 H20 Cooled AM3+ 8C DT 220W BE H2O Processor FD9590FHHKWOX$300
Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz DDR3 CL10 DIMM - Black (HX318C10FBK2/16)$116
Phanteks Enthoo Pro Full Tower Chassis with Window Cases PH-ES614P_BK$100
https://linustechtips.com/topic/323873-pc-build-help/
I doubt that you need the 8GB r9 290x, also I would get atleast an i5 4960k, and a 970. But what are you doing with the PC
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4400736
@gameinvestigator can you please tell us what you will be doing with this build?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4400769
to above. he said gaming on the top
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($222.75 @ OutletPC)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($128.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($115.98 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.98 @ OutletPC)
Video Card: XFX Radeon R9 290X 4GB Double Dissipation Video Card (2-Way CrossFire)  ($302.98 @ Newegg)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($115.99 @ SuperBiiz)
Total: $1544.61
Generated by PCPartPicker 2015-03-07 15:03 EST-0500
This would be a very good build. The AMD cores have weak cores and the i5 would beat it in single core performance.
Black and white color scheme.
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4400802
http://pcpartpicker.com/p/GNtRhM
Never get a 9590. Anything over an 8320/8350 is a waste of money, and runs too hot. If you're just gaming (which I presume you are, a 290x lightning is plenty), but you could always grab the 8gb if you really wanted. You could also wait until the new 3xx cards. The i5 is better for gaming.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4400822
A sound card is never necessary unless you want really high noise from your PC. And 290x isn't really that worth it.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.98 @ OutletPC)
Motherboard: EVGA Z97 FTW ATX LGA1150 Motherboard  ($159.99 @ Amazon)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($71.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($562.98 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($93.99 @ SuperBiiz)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($88.98 @ OutletPC)
Total: $1696.85
Generated by PCPartPicker 2015-03-07 15:21 EST-0500
i7's aren't that necessary for gaming, if your only use for this is gaming then step down to the 4690k. However if you wish to do video editing etc. Upgrade to 16GB of RAM and keep the 4790k
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4400924
I agree with the haswell build suggestion, but I would strongly suggest 16gb of ram instead of 8.
Main System: [Windows 10 Pro] [Core i7 5960x] [Asus Rampage V Extreme] [32GB 2400mhz G.Skill Value] [Corsair AX1200] [RXT 2080 Super] [Corsair H100i] [Thermaltake Core P3]
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4401301
Total: $1696.85
Didnt he say, he had hdd's? But anyways seems solid
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4402322
Do you want this guys power bill to sky rocket?
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  ($103.75 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory  ($129.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($99.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($549.99 @ Newegg)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($94.99 @ NCIX US)
Total: $1652.65
Generated by PCPartPicker 2015-03-10 17:48 EDT-0400
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4425110
The motherboard does not support the cpu. It does have decent sound, as do most enthusiast level motherboards. So the sound card is not really necessary. As others have pointed out the 8GB Ri 290X probably is not needed. What monitor(s) will you be using? Nice case, excellent psu.
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4430739
for one a frined of mine came me a list of part so i will update them here as for the monitor i was going to get 2
ASUS MX279H 27-Inch Screen LED-Lit LCD Monitor
UPDATED PARTS
 AMD FX Series FX-9590 8 Cores AM3+ 4.7GHZ
NZXT Technologies Kraken X61 280mm All-in-One Liquid Cooling System RL-KRX61-01
ASRock 990FX Extreme9
Corsair Dominator Platinum 16gb ram
EVGA 220-T2-1600-X1 1600W
and my frined is telling me to get 2
SAPPHIRE 100361-8GVXSR Radeon R9 290X 8GB  to have the pc hold up for some time
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4430824
UPDATED PARTS
You are spending money in the wrong places with that spec. An i5 4690K is a much better option.
The FX-9590 isn't a very good cpu.
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4430903
UPDATED PARTS
Could you please use pcpartpicker.com.
The psu is too large.
An ssd should be included.
As others have advised, the cpu is not a very good choice for a gaming system.
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4430946
This is much better.
You don't need an i7 or 16GB Ram at the moment for gaming, but you can fit it in your budget if you want it.
The 850W psu is enough for a 2nd R9 290X.
I would suggest a Freesync Monitor for gaming on. They should be out fairly soon. Then go with a cheaper monitor for your non gaming screen.
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($143.98 @ Newegg)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($334.99 @ NCIX US)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($114.99 @ Micro Center)
Total: $1285.90
Generated by PCPartPicker 2015-03-11 12:12 EDT-0400
https://linustechtips.com/topic/323873-pc-build-help/#findComment-4430960
