pc build help
Go to solution Solved by Guest,
I would stick with Z97.
If you want GTX 980 SLI then you want a 1440p or 4K screen to make the most of it.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($109.98 @ NCIX US)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Memory: Kingston Savage 16GB (2 x 8GB) DDR3-2133 Memory  ($121.99 @ Amazon)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card (2-Way SLI)  ($549.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($139.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $2288.87
Generated by PCPartPicker 2015-03-15 08:22 EDT-0400
well for the pc my lowest is 2000 butt i cold save up some more money to add more to like ram or a second gpu as for the  Monitors maybe 400.btw i am not planeing on get the parts tell like jun (unless there on sale some where)
If you are purely gaming (No video editing/rendering/streaming etc) then you can drop down to an i5 4690K and 8GB Ram. You could also drop the cooler down to the Coolermaster Hyper Evo 212.
So something like this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($143.98 @ Newegg)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($334.99 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($114.99 @ Micro Center)
Total: $1073.89
Generated by PCPartPicker 2015-03-11 12:20 EDT-0400
That leaves you with plenty of money for 2 Monitors.
But if you are not buying until June, then the new AMD 300 graphics cards should be ready for release. Also Broadwell (The next Intel cpu) should hopefully be available by then as well.
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4431062
Total: $1073.89
well for the monitors i was not planeing on get them untell latter on sic i have 20inc dell one that i can use
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4431078
o and i whated to ask if DDR4 is wirth the money and if i should save my money for now and what tell mid jun cuse by den i will have $2772 for the pc and just in case you don't not see i did say that i have some HDD here that i can use tell i can get a fast ssd
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4432461
DDR4 is a waste of money. It's like throwing it at an enemy at an RPG. It's not very effective.
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4432668
You won't see any benefit with DDR4 for gaming.
I didn't know if you had an SSD or not, but you can add one in if you need it. The Samsung 850 Evo is a good SSD.
http://pcpartpicker.com/part/samsung-internal-hard-drive-mz75e500bam
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4432908
so what should i get if i do save up for the $2772(-ssd and hdd) i looking for a good pc for game editeing steaming recording game play and maybe the basic 3d modleing.i what the best parts i can get for the money i am speeding i get the hole point of saveing money butt about $2772 i what i will have in mid jun and that what i am plane to speed on a pc i do have money set away for stuff like a head set muse and stuff thos thing are not need in a list you give me
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4433642
The spec I posted with the i7 4790K will do all that. If you are not buying until June though, then wait for the new AMD cards and Broadwell.
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4434088
may i ask what is roge about the build my frined gave me?
Where do I start.....
The FX-9590 is not a good choice to start with. It runs very hot (That is the main reason you need a high end cooler) and a lot of the AM3+ boards don't support it. You need a board that can cope with the 220W TDP.
The Ram is massive overkill both in quantity (32GB) and cost ($609). You only need 8GB or 16GB if you want to push the boat out. I wouldn't expect to pay any more than $150 tops.
Spending nearly $300 on a 6TB HDD is nuts. You can get 2 x 3TB Seagate drives or similar for less than $200 if you need that much storage.
The 8GB graphics cards are a waste of money. Just go with the standard 4GB ones. They might be useful for 1440p surround, but for a single 1080p monitor they are not really needed.
The 1600W psu is massively overpowered. You only need 850W for R9 290X crossfire.
All the extra fans are not really needed. The phanteks has pre-installed ones which should suffice.
You can get a slightly cheaper version of win 8.1. The 64-bit one listed at $89.98 is fine.
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4442317
i am fin with it runing hot sic my room is cold in the first place.and yes i know all of that is over kill with the ram i was planing on just get 16gb of it in the first place.i do what to ask and yes i am whating on the GPUs to come out but right now what is the bes GPU for about $600
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4442602
You can get a slightly cheaper version of win 8.1. The 64-bit one listed at $89.98 iso
so what wold be a better CPU
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4454467
i am look it on amozon it say it onley 4.4 the amd one 4.7 i dont see how that is better
Intel cpu cores are significantly more powerful than AMD. Understanding why that is requires a deeper understanding of cpu architecture than can be present here. You can verify the fact by looking at various benchmarks. http://www.anandtech.com/bench/product/1289?vs=1260 is fairly simplistic, but you should get a good idea of just how much more powerful the Intel cpu is.
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4455000
ok den so cold some pls give me a pc build for $2000 withe about $300-$400 to go over buget with no HDD or SDD as i have some that i just speed on the i have money give els saved up the pc is going to be use for game,steaming.recored,video editing,basic 3D modleing and GFX
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4456121
o and is any thing i can get for a anddord to find some where to putt my routher i have my pc wird to it butt i stell get wird speeds if i am up at like 3am its crap some times butt if it like noon i can play 720p videos on youtube even tho it say that is a time of day that for where i like in houstin a lot of pc are on youtube
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4456902
Total: $2288.87
https://linustechtips.com/topic/323873-pc-build-help/page/2/#findComment-4459993
