Hey there
I'm looking for a sub 120mm cpu heatsink for an LGA1150 socket. I'm running an Intel Pentium Anniversary Edition and I'd like to be able to do some decent overclocking on it without starting a fire
Current Rig
 CPU: Intel Pentium G3258 @4.0ghz MOBO: MSI Z87m-G45 RAM: Corsair Vengeance 8gb (2x4) CPU Cooler: Cooler Master Seidon 120v GPU: MSI R9 270x PSU: EVGA 500W 80+ Case: Corsair Air 240 (modded) SSD: Samsung 840 EVO 500gb HDD: Samsung 1tb Apple Hard Drive Mouse: Razer Naga 2014
https://linustechtips.com/topic/322786-low-profile-cpu-fan/
Looking to spend less than $60
Current Rig
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387235
i believe linus used one for a build for edzel a while back
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387238
Used one what?
Current Rig
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387272
Used one what?
don't konw what it was called all i know is that it was a low profile cpu fan
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387274
What's your budget? Honestly the stock cooler is good for up to 4GHz, if not higher.
that depends on how crazy you are. totally not good 24/7 but I did a stable 1 hour prime run at 4.7 ghz with no throttling
95C still isn't a good place to be.
I'd look into the Silverstone AR06
http://www.newegg.com/Product/Product.aspx?Item=N82E16835220069&cm_re=cpu_cooler_low_profiloe-_-35-220-069-_-Product
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387276
That looks pretty good. It's cheap too, thanks
Current Rig
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387305
There's some that are even cheaper, they won't perform as good but it will be a small difference on the G3258 since that chip barely puts out heat.
http://pcpartpicker.com/part/arctic-cooling-cpu-cooler-acfz11lp
http://pcpartpicker.com/part/thermaltake-cpu-cooler-clp0534
"Rawr XD"
https://linustechtips.com/topic/322786-low-profile-cpu-fan/#findComment-4387559
