cable confusion.
Go to solution Solved by MblaZe7run,
They all will work, but I always go DisplayPort>DVI-D>HDMI. HDMI 1.1 has a max of 60Hz refresh rate (iirc). DVI-D maxes at 120Hz (again, iirc), and I don't know what DisplayPort caps at, but yet again, if I remember correctly, maxes at about 480Hz. Please research the numbers and correct me if I'm wrong.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/322778-cable-confusion/#findComment-4387090
Honestly, it doesn't matter.
https://linustechtips.com/topic/322778-cable-confusion/#findComment-4387092
thats a lot better of an answer than i was expecting.
askdjfasdf
https://linustechtips.com/topic/322778-cable-confusion/#findComment-4387124
I'd say I aim to be above average, but in reality, I'm sitting on LTT forums instead of doing a case project for school because the topic has become boring to me and my grade is currently average-at-best.
https://linustechtips.com/topic/322778-cable-confusion/#findComment-4387135
