Define R5 fan placement?
By
Corruption
in Cooling
in Cooling
Solved by LogicalDrm,
2-1 is already enough for basic use. Maybe try that and see if you need to add more intake and exhaust. The 2-1 is 2 intakes and single exhaust, usually in rear. Using side exhaust isn't really practical since none of normal components use exhaust towards side panel. Non-blower style GPUs exhaust air everywhere so having side exhaust just for that isn't that practical.
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking16 -
apoyusiken ·
Posted in PC Gaming11
