Will this build work
Go to solution Solved by Atmos,
Thats a fine build esp for gaming, and pretty well priced for the budget.
One thing I would suggest is getting two 4gb dims of ram instead of a single 8gb dim, as then you can run it in dual channel and get a bit more performance out of it.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/322017-will-this-build-work/#findComment-4377193
Well, it will "work". However, you can do A LOT better with that money. As you don't seem to want to OC, here's my build for you:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.95 @ SuperBiiz)
Motherboard: MSI H81M-E33 Micro ATX LGA1150 Motherboard  ($45.99 @ SuperBiiz)
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($51.99 @ Amazon)
Storage: Transcend SSD370 256GB 2.5" Solid State Drive  ($89.98 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($328.99 @ Directron)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($69.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ Newegg)
Total: $991.83
Generated by PCPartPicker 2015-03-04 19:44 EST-0500
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/322017-will-this-build-work/#findComment-4377236
Hi im new to linus tech tips forums i was wondering if this build will work good i have a budget of 1000 dollars and i want a good gaming pc
http://pcpartpicker.com/p/7DwCvK
This build is better for your money :)
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.75 @ OutletPC)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard  ($106.98 @ Newegg)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($54.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($359.98 @ NCIX US)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($59.99 @ Newegg)
Total: $973.52
Generated by PCPartPicker 2015-03-04 20:02 EST-0500
"Rawr XD"
https://linustechtips.com/topic/322017-will-this-build-work/#findComment-4377342
Chill, the hype train is over.
Can the 290(x) be driven by a 430w PSU? No?
Then the hype train ISN'T over.... yet. The 3xx is still not here.
https://linustechtips.com/topic/322017-will-this-build-work/#findComment-4377356
Where did I say it could be?
The STRIX hype train, not the 970 hype train. Notice I also have a 970 in my build for OP, as well as my build.
"Rawr XD"
https://linustechtips.com/topic/322017-will-this-build-work/#findComment-4377385
