SLI HELP
Go to solution Solved by Oshino Shinobu,
but if you have sli set to maximum 3D performance then it only uses 1 monitor
Try activating all displays first, then enabling SLI. Also, have all monitors connected to a single card.
This is how I have mine set up and it works.
post-21359-0-51720700-1425492350_thumb.p
HELP ME PEOPLES!
I have 2 GTX 970's in SLI outputting to my main Monitor which has worked fine for months
ive decided to add 2 more monitors but i DO NOT want the 970's powering them (as i wont be gaming on them)
Since i added a cheap AMD card to the mix, i now have the other 2 monitors working just as i want them to but my 2 x 970's are no longer SLI'ed and i dont have an option to SLI them???
WHAT IS GOING ON :(
Thanks, Jamie
RIG SPECS: Corsair 800D case, MSI Z77 Big Bang Motherboard, i7 3770K @ 4.5Ghz with a H100i cooling it, 2x MSI NVIDIA GTX 970, 16GB PC3-14400 Ballistix Tracer, Corsair AX850 power supply, 3x 2TB WD HDD's, HyperX 120GB SSD. Monitor: 1x 27" ASUS Swift PG278Q & 2 x illyama prolite 24"
https://linustechtips.com/topic/321744-sli-help/
HELP ME PEOPLES!
WHAT IS GOING ON :(
Thanks, Jamie
What card are you using?
https://linustechtips.com/topic/321744-sli-help/#findComment-4373358
pretty sure NVIDIA isn't allowing an amd card to run whille running NVIDIA cards, could be false tough
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/321744-sli-help/#findComment-4373363
Its just a simple AMD HD5450
And all the cards work the 2 970's wont SLI though :(
https://linustechtips.com/topic/321744-sli-help/#findComment-4373367
No, pretty sure LMG ran two AMD cards in crossfire and two Nvidia cards in sli in the same system.
But they threw out a update afaik
https://linustechtips.com/topic/321744-sli-help/#findComment-4373378
You cant have SLI enabled with mixed grapics cards. I dont see what the problem is with the 970s driving the outside monitors. Just dont run the game on those monitors
BTW linus did a video similar to this and called some ridiculous thing.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/321744-sli-help/#findComment-4373379
https://linustechtips.com/topic/321744-sli-help/#findComment-4373381
https://linustechtips.com/topic/321744-sli-help/#findComment-4373395
these are my options
https://linustechtips.com/topic/321744-sli-help/#findComment-4373401
Sorry i just realised what you meant, gimme 2 secs and i will do that
https://linustechtips.com/topic/321744-sli-help/#findComment-4373407
This worked!! Thank you so much :)
https://linustechtips.com/topic/321744-sli-help/#findComment-4373522
