Hi Guys
I want to optimize my current build to get the most out of it without it being to pricey my GPU and CPU are not overclockt and i would like to buy a 128GB SSD but im not sure wat kind of SSD to chose
My current build
CPU: Intel Core i5-3350P 3.10Ghz
RAM: 8GB Corsair vengeance 2X4GB DDR3
GPU: MSI twin frozr GTX760 OC edition
Case: Coolermaster K280
Storage: WD 1TB green Drive
Motherboard: MSI H77MA-G43
PSU: Coolermaster B600
Operating system: windows 7 64 Bit
https://linustechtips.com/topic/321713-help-needed-to-optimize-my-build/
An SSD will indeed increase the general performance of your PC, time to boot, time to shut down, file transfer etc.. In games however, you will only see an increase in the time a map loads, it won't affect your FPS in any way.
I would go with the this drive ->  http://www.newegg.com/Product/Product.aspx?Item=9SIA2W02KJ5977&cm_re=120gb_ssd-_-20-721-107-_-Product
Its very good for the money.
So if your plan was to increase the general performance I second Nikoli.
i7 4770k // Scythe Mugen PCGH 4 // Asus Maximus VI Hero // Crucial Ballistix 2x 4GB 1866 CL9 // MSI GTX 770 2GB Gaming
