What would be good replacement fans for a H110? I won't be replacing them straight away I am just wondering.
I was thinking SP140 x 2 but then again, PWM would be useful.
https://linustechtips.com/topic/321574-h110-replacement-fans/
When I got my H100i I just got SP120 x 2 (because I got a smaller radiator than the H110). They work for me, but good point about the PWM. I personally do not care for PWM on these fans (even though they are on the louder side, it up to you which you choose)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/321574-h110-replacement-fans/#findComment-4371081
https://linustechtips.com/topic/321574-h110-replacement-fans/#findComment-4371096
Yeah I would only want quieter fans otherwise there is no point.
https://linustechtips.com/topic/321574-h110-replacement-fans/#findComment-4371100
True dat ^^^
https://linustechtips.com/topic/321574-h110-replacement-fans/#findComment-4371118
