DDR4 Dual stick kit compatibility
Solved by Techotic,
And then add another dual stick kit in the future? Will it run well or will they be compatibility issues? I don't want to buy 4x4 kits becuase it will limit my RAM capacity to 32gb!!
Yes there may be issues.
You can get that 16GB kit now, but it will be gimped (no quad-channel). I would get the cheapest quad-channel 16GB kit now, and if you upgrade later, just sell it off and buy a quad 32 or 64GB kit when the prices drop. Definitely NOT a good idea to run separate memory kits (including matching kits), especially when it comes to DDR4.
Read this: Don’t combine memory kits! The meat and potatoes overview
