Ok first off I checked if ninjaed but i couldn't see any other posts
Project Ara's Module's ready to be used in Puerto Rico
This is the testing design so whatever bugs or problems happen there it will get fixed before coming to the US.  I Hope
ME:  I want one but I really hope you can add a backplate to it
https://linustechtips.com/topic/321049-project-ara-modules/
Woot!
@AlexWalters08
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/321049-project-ara-modules/#findComment-4363623
