How to know your case temperature?
Go to solution Solved by Jade,
Put temperature probes in the case, or, if you're referring to part temps, Speccy / HWMonitor.
Pretty straight forward!
Thanks in advance!
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/320585-how-to-know-your-case-temperature/
Put a thermometer inside and check it after 30 mins. Jokes aside, Linus uses some laser one to check the temps of his components, not sure how it's called tho.
these
http://www.amazon.com/Nubee-Temperature-Non-contact-Infrared-Thermometer/dp/B00CVHIJDK/ref=sr_1_1?s=power-hand-tools&ie=UTF8&qid=1425330131&sr=1-1&keywords=thermometer
