980 or 970 SLI minimun or 290X CF
960 is not enough.
https://linustechtips.com/topic/320550-gpu-for-1080p-surround/#findComment-4356884
https://linustechtips.com/topic/320550-gpu-for-1080p-surround/#findComment-4356950
Heat will be a problem right?
The heat thing is blown out of proportion by nvidia fanboys. Trust me, amd is the brand to use in this setup. 290x preferably.
Wishing leads to ambition and ambition leads to motivation and motivation leads to me building an illegal rocket ship in my backyard.
https://linustechtips.com/topic/320550-gpu-for-1080p-surround/#findComment-4356960
I really thought that a 980 is more than enough for 1080 surround! I guess I'm wrong! But I can't afford more than 600 bucks on the gpu!
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125505
$300 x 2 = $600
If that's too much, then look at used\
-btw crossfire 290 is way better than a single 290x
https://linustechtips.com/topic/320550-gpu-for-1080p-surround/#findComment-4356995
