So I will be doing wedding photography for my mates brother and it will be my first time shooting a wedding and don't know how much to charge. I have been doing photography for about 2 years now and have all the gear I will be there for about 9 hours or so
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/320336-how-much-should-i-charge/
No I do it as a hobby but I do it quite a lot
If you aren't established as a professional... I wouldn't charge more than 60% what the people who do this all the time do it for. You have to work up a proper portfolio, and no matter how much you do it, no one is quite as good as they think they are.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/320336-how-much-should-i-charge/#findComment-4353922
Maybe it's the moment to try to see if it can be your work.
Take it as a challenge and a professional work even if you didn't do it yet.
For the charge it's simple evaluate the cost, the selling prices of locals and place yours.
Good Work ;)
"Innovation is the only way to progress"
"To every action there is always an opposed equal reaction"
"There is only one road, always straight"
https://linustechtips.com/topic/320336-how-much-should-i-charge/#findComment-4355433
