Okay so I had a few questions.
What is different from air cooling (installing wise, maintaining wise (its an AIO))
Any tips I need to know
Any water cooling "secrets" that I need to follow at all times?
Stuff like that, thanks :D
https://linustechtips.com/topic/320261-water-cooling-noob/
AIOs are not really different. Don't pull the hoses out of the fittings and you'll be fine. And they're maintenance free (AIOs at least)
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4352895
How do I do this "leak test" people speak of?
Even if I usually wouldn't have to do it, it will be a refurbished AIO so I would like to do it to be safe.
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4352906
have your pc off and put the pump on so the water circulates. Place paper towels on components (GPU, PSU, case floor) and let the water circulate and check for water drops on the paper.
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4352918
Could I not just have the radiator plugged in but lying on the table with paper towels under it?
Will that not reduce danger by over 9000?
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4352926
Or just do it like that. I was talking from experience with custom loops :P Can't take that sucker out for leak testing ;)
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4352941
Touché
That would be terrible because if it did leak you would have to wait like 2 weeks for the water to evaporate.
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4352948
Custom water cooling or Close looped water cooling?
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353045
you can(depends some pumps need usb other connections other than 4pin), but if you already installed it and have been using it for years that's pretty much impractical to remove it just to check
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353046
Close looped.
I'm buying one, why would I leak test a radiator I already installed? :P
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353062
You really don't need to leak test an AIO mate, If it hasn't leaked by the time it gets to you then It's pretty safe
Just me being paranoid :P
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353083
Better safe than sorry I guess. But honestly an AIO will be watertight, if it isn't it will have already leaked because it's filled from the factory :)
Good luck with the hunt, I just got a H110 for my rig and I'm gunna spend the night installing it and playing about with it :)
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353092
Close looped one eh? You don't need to do leak test, but if you're trying to custom water cool it you need to do leak test.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353094
Nice! Even though the H100 is ugly, I found it for £50 and it's a deal I can't refuse :P
https://linustechtips.com/topic/320261-water-cooling-noob/#findComment-4353099
