it is idleing. if it is not in use it will drop voltage (richt upper corner) and the multiplier to save energy
        wow... pretty empty here...
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337086
My first guess would be nothing: your CPU could be dynamicly downclocking itself under low load to save power. Have you tried running something like prime95 and then see what CPUZ gives you?
No I didn't want to because I was unsure of the stability, should I try it?
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337096
Lawl, how did you validate your OC then ?
EDIT: You can also use aida64
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337114
I think you need to look up some basic overclocking 1-o-1.
In order to know how "far" you can overclock, you need to do little (like, 50Mhz or even less, esp. if you are unfamiliar with overclocking) steps. After each step, you then boot your system, and run something like prime95.I would advise combining it with something like furmark to also heat up your GPU, if the air your CPU cooler uses to cool is hotter (due to the gpu) it's cooling power will be lower. You let this run for at least 15 minuits at the start, while constantly monitoring the tempratures. If they go to high (say, 75C to have some margin) during this test, you have hit the limit, and need to turn of the system, and go back a step in the overclocking. If it doesn't, and runs stable, you turn of your system, and do another step faster. You repeat this untill you hit your limit. Once you did, you should let it run prime95 for 12 hours min (I would advise more, like 24 hours or longer) to check if the overclock is stable (just because your tempratures are OK, doesn't mean it will be stable). If it is, you have hit a stable overclock and can let your settings be. If it isn't, you either have to up the voltage (but be carefull, I think that eventhough modern processors have temprature limiting, you can still break them with too much voltage) or you have to drop the overclock back a step, and repeat.
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337158
In your BIOS you can configure the CPU to never downclock.
running prime 95 im now getting 4181.23mhz on the core clock, is that right?
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337172
yes now leave it running for about 30min atleast, and then do more if you so desire I don't recommend Prime95 since it should make problems with Haswell, go with Aida64
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337186
yeah i do xD, im getting around 69/70c on average at the moment. is that ok?
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337191
i just dowloaded Aida64, now how do i benchmark? sorry, major noob here :P
Better watch some videos before playing around with your CPU tbh
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337240
OP has Ivy, not Haswell. P95 is completely fine with that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/319054-overclock-help/#findComment-4337515
