Hello all. My current computer is running on its fifth year and is due for an upgrade. I was curious as to which case I should get next. I will most likely be upgrading the case, power supply, motherboard, and processor. I have looked into all sort of cases but am curious as to what you all think. Water cooled or air colled, it is all the same to me as long as the case is somewhat quiet and a large tower to fit multiple graphics cards. I have no real budget, just looking for opinions. Thanks.
https://linustechtips.com/topic/318188-next-pc-case/
Fractal Define R5, Corsair 760T, beQuiet Silent Base 800
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/318188-next-pc-case/#findComment-4325097
Define R5 + An extra 140mm fan to boost intake capability.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/318188-next-pc-case/#findComment-4328863
I love my windowed R5, it loses some sound proofing for the window but it looks great.  If you need more than 2 5.25" drive bays or want to water cool/AIO with a 240mm radiator, the BeQuiet is probably better but it is bigger than the R5 for sure.
If you get the R5, I highly recommend putting a second 140mm fan in the front.  I took the stock rear fan and moved it to the front and then put an H80 in the rear exhaust spot.  Doesn't cool any better than an air cooler but looks nicer in my opinion.  Th H80 is by far the loudest thing in my case, fine at idle but when it ramps up it is loud, I need to replace the stock fans to try and quiet it eventually.
Fractal Design Define R5 | i7-4790k | Corsair H80 | Asus Z97-Pro WiFi | 2 x EVGA GTX 970 SSC+ | 16GB G.Skill Sniper@1866MHz | Samsung 840 Evo 256 GB | 1TB + 750GB drives | EVGA 750W G2 | 27" BenQ IPS 1440p@60Hz | Windows 10
https://linustechtips.com/topic/318188-next-pc-case/#findComment-4329107
if you want all the room you are ever likely to need, and plenty of support for water cooling,
Thermaltake Core X9.
Been trying to push that case for a while, I want to see some ridiculous build logs of it in the workbench area soon lol
Dubs are better than subs
https://linustechtips.com/topic/318188-next-pc-case/#findComment-4329132
