Fan Compatible with Case/Mobo?
Go to solution Solved by MegaDave91,
The NHD14 will fit.
I'd prefer to install the NH-D14, but I doubt it'd fit. So I'm wondering if the NH-U9B SE2 will fit, if not how about the NH-U12? I would figure it out myself, but I'm not entirely sure how other than to take the dimensions of the CPU cooler and compare them to the motherboard.
Case: Antec One
Mobo: Gigabyte GA-78LMT-USB3 (rev 5.0)
Thanks, all feedback is appreciated :D
PC: Ryzen 2600X, EVGA 1080 DT, Gigabyte X470 Aorus Gaming 5 WiFi, Corsair 2x8GB DDR4 3000Mhz, EVGA SuperNOVA G2 750W 80+ Gold, Phanteks  Enthoo EVOLV ATX
Peripherals: Logitech G502 HERO, Cooler Master ML510, Corsair K68 Cherry MX Red, Dell S2417DG YNY1D 24" 165HZ G-Sync 1440p, Acer XF251Q,
Audio: AKG K7XX, JBL SLR308 MKI, Scarlett 2i4 (2nd Gen), Sony MDR-7506, Shure SE-215, Audio-Technica AT2020
Server: Dell Poweredge T420 running ESXi, Hosting Plex and Automation services and misc. game servers; 2x Xeon E5-2400, 32GB ECC Memory, ~40TB Storage (Mix of SSDs and HDDs)
Network: Asus RT-AC3100 (Current), Supermicro running pfsense, 10/100/1000/10000 Netgear Switch
https://linustechtips.com/topic/316397-fan-compatible-with-casemobo/
The NHD14 will fit.
The NHD14 will fit.
Thanks. Would you happen to know if the 15 would work as well?
Not sure of its dimensions, but I'm inclined to say it's not any taller than its predecessor.
The Antec one's side panel is concaved, so I don't see it being an issue.
okay, thank you.
okay, thank you.
You're welcome. :)
