Hey there :) After Project Inverted I started on a new build called Project 180. (P180)
Not a scratch build this time, but a rebuild of an exisiting case, the Antec P180. Why this case? Well simply because I had it sitting around after building Inverted. Hardware will be added along the way of the build.
(I've already been working on this for a while and already have a couple of buildlogs online, so some of you might have seen this. Didn't know of this forum till about a week ago.. (shame on me!) I'll update this thread along with the others as I progress from now.)
Allright, so without further ado, here's Project 180
Picture time!
Disclaimer: I try to make nice pics as much as I can, but unfortunately I do not have a good camera (It's on the wishlist!)
Most pics are made with my iPhone 4s, but some are with a Casio Exilim.
Standard Antec P180 housing
001
Again I'll be using 25x25mm aluminum tubes
002
Cut away parts of the original front to make room for the alu tubes
003
All alu bars in place, 3mm transparant plexi in between
004
Finished the top and bottom with a alu strip
005
Testfit of the front
006
I want to put 2 fans in the front that will draw air from the bottom of the front through the tubes. They won't be able to breathe much, but hopefully enough for what I want to do
Sketchup of the fan cutout in the front
007a
This is what it looks like so far,  the 2 outer tubes still need to be cut
007
ZdMods
Finished builds Red
 Project 180 • Project pǝʇɹǝʌuı • Harman/Kardon HTPC
https://linustechtips.com/topic/31598-zdmods-project-180/
Cut all the tubes and test fitted some fans
008
The plexi strips had some damage from cutting them, when lit this was clearly visible so I had to file down the plexi another 2mm to get a smooth edge on the plexi
Before
009
After
010
Attached the new front to the plastic bevel
011
012
Front on case
013
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-403903
Because I want another layout in the case I dont need much of the original metal frame, so I've cut up the front and backpanels and replaced the midplate
First I stripped the whole case
014
After cutting not much of the original parts are left
015
Added aluminum panels to the front and back
016
And rebuild the case with new panels in place
017
018
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-403916
Took the I/O panel from the original back and put installed it in the midplate. No idea how this kind of orientation is called, so I'll just go with BTX180 :D
019
020
Up next was the top of the case. Cut 2 pieces to size and cut 3 rectangular slits in the side. This way I can still use the original sidepanels. The 'clips' on the sidepanels will slide into the bars
021
Cornerpieces on the front and back to support the top
022
023
024
026
With the sidepanels installed it all aligns nice and tidy
025
And I had a go at polishing, the strips on the front are sanded with P800 and then polished with Commandant #4
027
028
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-403932
Continuing on the top, added 2 corner pieces to the bars that were already there, in between I put the same plexi as in the front
From the top it now looks like 4 solid bars, but infact there is room to fit a 360 rad underneath
037
038
And added a small piece of alu on the back
039
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-403950
And now some hareware I've collected
CPU block
040
041
042
OZC Vertex 4 128Gb ssd
043
044
045
Alphacool Nexxos ST30 240 & 360
046
047
240
048
360 with Coolermaster Excalibur fans
049
050
The 360 radiator is installed in the top. I've added 2 smaller corner pieces, these are mounted to the same threaded ends that hold the whole top together (2 in total)
This way the radiator can be mounted on the smaller corner pieces, and there are no visible screws in the top once installed. (pretty proud on that actually :D)
Top (upside down on pic)
051
052
With 360 rad in top
053
054
And now, dinner.. more later!
Cheers,
Meelobee  :ph34r:
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-403965
Thanks guys :)
Allright dinner is done, here we go with the next batch of pics:
The top again
And here it is installed on the case
Got both rads in place, unfortunately I made an error during the measuring, resulting in the front rad being to close the the top rad, and the fittings of both rads got in eachothers way.
So the front rad is now mounted upside down, a bit harder to fill the loop/clear air now, but not a big problem.
Another downside of the front rad being mounted upside down is that the fins of the rad are clearly visible, and they show alot of copper (ie bad paint job)
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404021
To hide the ugly copper fins on the rad I've decided to cover it up! For this I've cut 2 aluminum corners to size
055
Then cut a piece of 2mm alu and attached some hexmesh to it with malleable metal
056
Attached it to the rad
057
Made similair pieces for the 360 rad in the top
058
From the side both rads are now hidden. Also visible here is a bar under the midplate, this will be the tray to lead the wiring to the back of the case
059
Added a window/venthole in the backpanel
060
061
3mm white leds installed in the plexistrips on the front. The light is not equal yet as the plexi is not totally smooth. But this gives a nice indication on how it should look in the end..
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404053
Installed the PSU
Cut a hole for a window in the sidepanel, this will be finished with aluminum later on
Filled the holes on the plastic parts of the front of the case with filler and sanded the whole plastic bevel to grid 2000 to get rid of the fine structure the plastic had. It's now smooth as silk.
Made holes in the radcover so the fittings...err... fit :D
Started on the mobo backplate, this is made of 2 aluminum plates with a piece of 5mm black plexi in between
Behind the backplate there is almost 4cm of room to hide cabling, tubing, etc from view
More hardware!
Luxury problems, which one to use?!
I favour the Supremacy
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404086
Up next is the right sidepanel, the original case has a thin aluminum sheet on the plastic side. I removed the sheet and cut a big rectangular(-ish) hole earlier.
On top of this big hole comes a new 1mm thick aluminum panel, which will have the actual window. The window has a simple shape, but has logo in the lower left corner. All this is cut and filed by hand!  B)
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404126
More Hardware!
Got a nice midrange mobo for the build, a Gigabyte Z77X-UD3H
Then I raided my wife's bathroomdrawer to get her nailpolish remover (=Acetone) and used it to remove the blue text on the caps
Hiding the 24Pin ATX cable!
I've cut a U profile into size and gave it some bends, and cut a small piece of 1mm alu plate as a cover
Fits together like this
And is mounted on the backside of the mobotray like this
Screws/bolts will be countersunk ofcourse
The ATX connectors of the mobo and the psu are aligned within a few mm (unfortunate miscalculation..) all it needs now is a short (10-15cm) extensioncable to attach it
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404141
Made a cover for the PSU/Pump bay
Added a window to the cover, the rectangular hole on the left is for the one of the clips of the sidepanel. Too bad I can't remove the clip from the panel, if I do the panel doesn't keep flush with the front
Quick polish on the sidebar
Had a go at brushing the midplate, not too bad, but not good enough either, need to figure out a way to get a nice straight brush effect. Otherwise it will be painted.
Pomp/res/flowmeter combo
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404188
In this build I want to use hard/straight tubing. Downside of this is the massive amount of fittings needed for a relative simple connection.
These are the fittings needed to connect 2 rads and the cpu block to the midplate
BP Matt-Black fittings come with green O-rings, They will be replaced with black O-rings
Like this
Combined you get something like this (Tubing is E22 UltraClear)
Made holes in the midplate for the passthrough adapters, 22mm in diameter so I got some margin to move the adapter to the exact position
And then cut and installed the tubing
Polished the radcovers
And lastly all the plastic parts of the sides and front are in their first layer of primer
That's how far I've got with this build so far. I'll update this thread as I continue. Thanks for reading!
Cheers,
Meelobee
ZdMods
Finished builds Red
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404214
Hehe, good to see this here as well. :)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404300
That looks AMAZING, really like how the tubing going in and out of the reservoirs look.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
https://linustechtips.com/topic/31598-zdmods-project-180/#findComment-404427
