Our prayers have been answered !!
Gravity box is live for lollipop !!
http://www.xda-developers.com/gravitybox-makes-massive-return-to-lollipop/
What is Gravity Box?
https://linustechtips.com/topic/315895-gravity-box-for-lollipop/#findComment-4293080
Now if only Xposed worked properly.. it's just in alpha.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/315895-gravity-box-for-lollipop/#findComment-4293190
it works properly .. kind of .. you need SELinuxModeChanger switched to Permisive , then Soft reboot your phone trough Xposed module framework (moto G '13 owner here with 5.0.2)
CPU : i5 4670k @ 4.2Ghz | Cooler : NH-D14 | GPU : Sapphire Radeon HD 7870 [OC] | MB : Asus Z87-Pro | RAM : A-DATA 8GB 1600Mhz CL9 XPG Black | SSD : 850Evo 250GB
https://linustechtips.com/topic/315895-gravity-box-for-lollipop/#findComment-4293256
