Hello,
Greetings,
So I got a dremel recently and have played around with it quite a lot.The one thing I am proud of is the engraving I made on my side panel.How is it?Please rate it from 1-10,keep in mind that this is my first engraving so go easy on me.
Stencil- simple_pumpkin_outline_msu_pumpkin_patte
Any tips?
Thank you.
https://linustechtips.com/topic/315404-my-first-engraving/
-SNIP-
Looks nice, how long did it take to do something like that?
Also just a tip you want super crisp edges there are hand engraving tools to cut and outline before engraving/cut out the material they're usually used for work such as jewelry.
https://linustechtips.com/topic/315404-my-first-engraving/#findComment-4290335
It took about an hour to complete it.Thanks for the tip!
https://linustechtips.com/topic/315404-my-first-engraving/#findComment-4292563
