Case temps?
Solved by LogicalDrm,
The temp inside the case would be 30C-50C, depending on place of sensor. On top of HDD, right next to intake, 30-35C. Near GPU 45-50C. Near CPU heatsink around 40C.
For the components temps will be higher as they are measured straight on chips.
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
