Hey guys
i ordered an hyper 212 evo and it should be here on tuesday.
I ordered it because of my cpu high temps, (99°C on 100% load) and since i have everything in the case, is it safe to assemble it in the case? I mean i'm not working on carpet and i have a wood table but since i have my mobo grounded to the case i should be fine, right?
Thanks in advance, bye!
https://linustechtips.com/topic/315265-hyper-212-evo-installation/
Well yeah... you should be fine
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
You will be fine even though the mounting system is not my favourite at all, the coole is still able to wiggle a bit but its okey :)
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
hey, im going to do my first build in a few days, and i have a wood table and a wood floor, is this safe from static electricity? and does wearing a pullover increase my chances of frying my components?
Thanks to everyone! I'm relieved now!
I think with parquet you'll be just fine...
Wearing a pullover will increase the chances of ESD, yes. Try to wear as little clothing as possible (I'd reccommend a t shirt)
