Bloody hell. BitFenix Prodigy?
Your funny.
Aerocool DS case.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/314725-3-slot-mini-itx-case/#findComment-4278194
Sounds really stupid, I know. but i really want to go itx with a bigass graphics card
NCase M1
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/314725-3-slot-mini-itx-case/#findComment-4278195
I've never got taht Simpsons reference in your sig. Explain?
Okay. You know the book See Spot?
See Spot.
See spot run.
Run spot run.
Well everyone obviously mentioned THAT half already, the other half is the old DOS programming, dos being the base of windows. For example:
A:/F:/
F:/Setup:/
F:/Setup/C:/
Much like this,
C:/DOS
C:/DOS/RUN
RUN/DOS/RUN
WAS an ACTUAL Command. which HAPPENS to correspond with the story.
Because he had a hard drive.
https://linustechtips.com/topic/314725-3-slot-mini-itx-case/#findComment-4278262
See Spot.
See spot run.
Run spot run.
A:/F:/
F:/Setup:/
F:/Setup/C:/
Much like this,
C:/DOS
C:/DOS/RUN
RUN/DOS/RUN
haha that's actually quite funny
https://linustechtips.com/topic/314725-3-slot-mini-itx-case/#findComment-4278268
Its more of an µatx case but it will fit you needs:
Case: Aerocool DS Cube Black Edition Silent Cube MicroATX Mini Tower Case  ($98.99 @ Directron)
Total: $98.99
Generated by PCPartPicker 2015-02-21 11:08 EST-0500
Let's agree to disagree
https://linustechtips.com/topic/314725-3-slot-mini-itx-case/#findComment-4278511
