Painting PCB edge on GPU
Go to solution Solved by QueenDemetria,
Hey,
Yep, a Sharpie would work fine.
Also it might void your warranty, not sure though.
Hey,
I got a question. A while ago, somewhere here on LTT I read a dude painted the edge of the PCB on a GPU with a black marker. Is it safe to do it? I would like to do this myself, that would perfectly hide the yellowish color of the PCB edge :)
Pic for reference:
Thanks
https://linustechtips.com/topic/314652-painting-pcb-edge-on-gpu/
Go for it
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/314652-painting-pcb-edge-on-gpu/#findComment-4277243
Hey,
Pic for reference:
-PIC-
Thanks
Yeah it will work I'd personally use an enamel paint since it adds some thickness to it but a sharpie or black paint marker will work.
https://linustechtips.com/topic/314652-painting-pcb-edge-on-gpu/#findComment-4281222
