Hi,
Here's what's happening. I have 8gb of RAM installed. My Task manager displays it correctly but when I start google chrome+any other game my RAM jumps to around 3.47gb used it's aruong 40% according to Task Manager, However I suddenly get this message that my computer is running out of memory and my game automatically closes and google chrome crashes. I usually encounter this issue when I was using my old PC which has only 4gb of RAM however this PC that I'm using has 8GB. Is there some kind of memory leak? Help me guys.
Mobo: Gigabyte G1 Sniper M3/ Processor: Intel 3570k @ 4.5Ghz / Memory: 2x4 GB DDR3 1866Mhz Corsair Vengeance
VGA: Powercolor 7870 Myst SSD: 128GB Crucial M4  / HDD: WD Green 2TB
Power Supply: Seasonic S12 620w Case: Fractal Design Define Mini / Cooling: Corsair H80
https://linustechtips.com/topic/31457-help-memory-problem/
Are you running Windows 64 bit?
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-402327
Yes I am.
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-402711
I'm using my PC for about a year already and this just started happening a month ago
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-402713
Does it happen consistently? And does Windows recognize the extra RAM?
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403066
Yes it does recognize it. Kinda weird I am starting to get issues on 40% mark...
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403425
Try reinstalling Windows. Does your BIOS recognize the RAM?
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403536
yes my BIOS does recognize it. Damn I really hate reinstalling windows...  -_-
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403607
There may be some other option. Maybe doing some kind of live boot off of a flash drive with Ubuntu or something.
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403609
you know how to do it? I'm not familiar with that method.
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403639
You have a flash drive?
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403641
yes.
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403668
How large?
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403670
a 4gb and an 8gb
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-403760
  • 3 weeks later...
a 4gb and an 8gb
You could turn your flash drive into a bootable medium using some kind of Linux distro.
https://linustechtips.com/topic/31457-help-memory-problem/#findComment-467294
