CPU decision help
Solved by KamiKatze,
Thanks for answering everyone.
I live in Switzerland so the prices aren't quite the same, it's about a 60 CHF difference between the i5 and the 8320 and about 80 CHF difference between the 860k and 8320.
@KamiKatze, yes, I'm building a new computer, but I wasn't really certain with the CPU. But you're all saying the 8320 is better than the 860k, so I'll go with that
Thanks again everyone
Well that's obvious because it is more expensive. What's the i5 4440 or 4460 in switzerland? That would be a goodalternative to a FX 8320.
