are you wanting to run the sensor and light system on a independent network?
The sensor will be on one network and send a signal over the internet to a light (another Rasberry Pi).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
ok, then a wireless switch like the Belkin should work as that is a network connected switch with a unique ip address. A quick search lead me to this which should be helpful when it comes to controlling a wifi switch.  http://concisionandconcinnity.blogspot.com/2013/02/ouimeaux-command-line-and-python-api.html
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
