Could I buy (or make, and if so how) a pressure sensor that would send a signal over a wireless network and turn something on?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/312520-a-wireless-pressure-sensor/
What type of pressure sensor are we talking about?
Something that could (ideally) sense weight on a pillow, or if not, then just a simple plate sensor would do.
I'm guessing the cheapest way would be to buy some pressure sensor (do they make pressure strips?) and hook it up to a Rasberry Pi and then network it?
PSU Tier List | CoC
You'd be better off with a trip sensor in that case. Pressure sensors work better on hard surfaces (usually)
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
How would a trip sensor work, aren't they usually based off of lasers?
Would something like this work? https://www.sparkfun.com/products/9674
PSU Tier List | CoC
No. There are different types. I've done one as a motion sensor by soldering a spring onto a base with a certain distance off the other terminal. It moves, it hits the other terminal, closes the circuit, bam, you have a trip switch.
Best way to find out is to try it! :P
pressure as in air pressure or a load sensor? If you need a load sensor, these should work. http://www.amazon.com/Silver-YZC-161B-Aluminium-Weighing-Sensor/dp/B00IHUJQUK/ref=sr_1_10?ie=UTF8&qid=1424234157&sr=8-10&keywords=load+cell
Get those and an arduino with a wi-fi shield and you should be set.
Edit: now that i read your more recent post's, maybe a capacitive sensor would suit your needs better? What exactly are you trying to do if you dont mind me asking?
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
Lol I don't know anything about sensors, but i wonder what you're planning to do with it?
Like turn off the lights when you land on the pillow or something?
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
Would that be better than this: https://www.sparkfun.com/products/8606
And this is what you're talking about? https://www.sparkfun.com/products/11287Would there be something cheaper?
PSU Tier List | CoC
Use case would be handy to give you what you need.
Someway to sense weight on a pillow and then send a signal over the network and turn on a light.
PSU Tier List | CoC
now that i have read your more recent posts, i am thinking maybe a capacitive system might work better. Do you need a accurate weight or force reading or do you just need a detection system? as for the wifi, there are much cheaper options available. It just depends on the kind of range you want. http://www.amazon.com/Adafruit-Breakout-Onboard-Ceramic-Antenna/dp/B00H232MUE/ref=sr_1_7?s=electronics&ie=UTF8&qid=1424235031&sr=1-7&keywords=arduino+wifi
this http://www.amazon.com/Adafruit-8-Key-Capacitive-Touch-Sensor/dp/B00K9M6RF6/ref=sr_1_4?s=electronics&ie=UTF8&qid=1424235139&sr=1-4&keywords=capacitive+sensor
and some conductive thread may do what you want.
No, I don't need an accurate reading -- just enough to determine if someone's head is on the pillow vs. not.
For range, I'm assuming you mean signal strength? It just needs to be able to connect to a wifi router that could be at most a couple rooms away (i.e. somewhere in a 600sqft apartment).
But would a capacitive sensor work through a pillow? I was actually thinking about capacitive/temp sensors, but I didn't think either would work/well.
PSU Tier List | CoC
in that case, a capacitive sensor system like the one i linked would probably be the best bet when it comes to being un-intrusive. All you would need is to get some kind of conductive material like conductive thread on the pillow and you would just have one wirer going down to an arduino or raspberry pi.
So, then, is this all I would need:
https://www.sparkfun.com/products/10867
How much thread would be needed? (would it be annoying/obviously visible?)
And lastly, how would I go about setting everything up? (setting up the Arduino part -- not the capacitive sensor part).
PSU Tier List | CoC
actually, now that i think of it, a raspberry pi may be better for your use than a arduino and i think you can do it cheaper too. http://www.amazon.com/Raspberry-Pi-Model-512MB-Computer/dp/B00LPESRUK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1424236306&sr=1-1&keywords=raspberry+pi
Get the raspberry pi plus a wifi dongle like this along with the capacitive components and you should be all set.
http://www.amazon.com/Patriot-Mini-Wi-Fi-Adapter-PCUSBW1150/dp/B007JRC95Q/ref=sr_1_22?s=electronics&ie=UTF8&qid=1424236091&sr=1-22&keywords=raspberry+pi
This should be usefully to get the capacitive sensor working if you decide to go with the rasbbery pi over the arduino https://learn.adafruit.com/capacitive-touch-sensors-on-the-raspberry-pi/overview
So I'd just need:
Would I need to know anything other than whats in that link you just linked?
How much thread would be needed? (I don't want it to look stupid/uncomfortable with a metal band of wires running through the pillow).
Also, how could I go about hooking up a light to a second Rasberry Pi (over the internet) -- i.e. when the capacitive sensor is triggered a signal gets sent over the internet to a second rasberry pi and turns on the light?
PSU Tier List | CoC
So I'd just need:
that should be it for the wifi sensor side. For the thread, i would start with one strand across the pillow and if that is not sensitive enough run one or two more strands in parallel with the first. As for the light, i believe that can be done without another raspberry pi with one of these. If it is for a room that is. http://www.amazon.com/Belkin-WeMo-Light-Switch-Enabled/dp/B00DGEGJ02/ref=sr_1_1?ie=UTF8&qid=1424237665&sr=8-1&keywords=Belkin+WeMo+Light+Switch  There are also wifi controlled outlets too.
The capacitive sensor will trigger a light on a different network, so...
PSU Tier List | CoC
"sense weight on a pillow" MURDEROUS :P, lol
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
are you wanting to run the sensor and light system on a independent network?
