So my 4770k, as many of you know, gets kinda hot. I currently run a H80i and i have my CPU running at 4.2ghz and it seems its thermal throttling. I am lagging bad in game lately and I doubt its my GTX 780. I am only playing on one 1080p monitor so it shouldn't be stressing my graphics card. I am also running the latest drivers on there.
Anyways, whats the best AIO cooler out there?
H100i/ Kraken x61/Nepton 240m?? Or another?
Would love to know which one out there would give me the best performance. Thanks again.
https://linustechtips.com/topic/312455-4770k-cooling/
to be honest your not going to see that much of a preformance difference with a aio or a air cooler, if your case can support it just  go with the noctua nhd-15
Its a Championship not a Belt!
https://linustechtips.com/topic/312455-4770k-cooling/#findComment-4246886
Kraken x61 HANDS DOWN.
Heres my 5.1ghz run and it stayed below 95c.
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/312455-4770k-cooling/#findComment-4246919
If you still want to know, X61 is the best and plus the rgb light
https://linustechtips.com/topic/312455-4770k-cooling/#findComment-4246924
I am ok on spending a little extra so my rig looks a little nicer. Noctua (to me) doesn't have the most pleasing look to their components.
Jeraki( then whats the point of buying a "K" version)
then go the coolermaster evo 212 the everloving shot to hell cooler that preforms like a beast and strap what ever fans you prefer on it.
https://linustechtips.com/topic/312455-4770k-cooling/#findComment-4246937
I also have a 4770k+780 combo playing @ 1920x1080 i guess im wondering why you're needing to overclock?
I would understand if the system is getting a little old and cant handle current titles anymore it makes sense to overclock and prolong the life of your system, just curious more than anything else :)
https://linustechtips.com/topic/312455-4770k-cooling/#findComment-4247051
