i just got my parts form the mall and i put my motherboard and cpu and gpu together but there no display but the cpu fan and gpu fan are tuning on i don't know what to do now
if you're plugging in the display cable into the gpu, try the motherboard's port to use your cpu's integrated graphics (if you're using intel which i am guessing you are). vice versa
https://linustechtips.com/topic/312454-help-first-pc-build/#findComment-4246882
