Umm... yeah it's a great case. Looking at it currently for a build I'm prospecting for a friend and leaning very heavily toward going with it.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/311860-define-r5-water-cooling/#findComment-4239659
I think you should get a larger case. Looks like you may have to give up some stuff if you want to mount rads everywhere. Btw i don't own a r5
i7-5930K@4.7Ghz | Asus X99-E-WS/USB 3.1 | Corsair Vengance 32GB DDR4@2666Mhz | Duo Gigabyte GTX 1080 Xtreme Gaming | Samsung 950Pro 512GB | LSI 9260-8i RAID Card | 6x 1TB Samsung 850 Pro (RAID5) | Corsair AX1200i |  Fractal Design Defiine R5 Black | MetaDot DasKeyboard4 Professional | Logitech G900 | Windows 10 Pro 64-bit | Asus PG348Q
https://linustechtips.com/topic/311860-define-r5-water-cooling/#findComment-4242335
The case can fit a triple 140 in the top and triple 140 in the front. Why would he need a larger case? Even going with a dual 140 and triple 140 is more surface area than two triple 120s and comes close to 7x120mm. The Define R5 is great for radiator capacity -- the main reason I'm going for it.
https://linustechtips.com/topic/311860-define-r5-water-cooling/#findComment-4242348
