Hey everyone,
I'm looking to make a gaming pc for around $1200. I want to get the best bang for my buck.
Requirements/Specifications:
- Play games like battlefield 4 at 1440p
- Intel i7-4790k/ Intel i5-4690k (whichever makes the most sense)
- Gigabyte GeForce GTX 970 G1 Gaming GDDR5 Pcie, 4GB (or something else?)
- 16GB of ram (whatever fits the budget)
- SSD around 120GB
- HDD around 1TB
- Mother Board to support all this
- Nice power supply (willing to spend a little more on this)
- Cooling options (Not sure what's best)
- Any case to fit this build
- Looks aren't important
- WIFI is a must!
- Display if it can fit in the budget
Thanks!
Looking forward to hearing some suggestions.
https://linustechtips.com/topic/311670-build-help/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($54.99 @ NCIX US)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($76.98 @ Newegg)
Memory: Patriot Viper 3 Low Profile Blue 8GB (2 x 4GB) DDR3-1600 Memory  ($61.99 @ Newegg)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($84.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  ($549.00 @ NCIX US)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($43.99 @ Newegg)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.88 @ OutletPC)
Total: $1141.76
Generated by PCPartPicker 2015-02-16 16:31 EST-0500
https://linustechtips.com/topic/311670-build-help/#findComment-4236386
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard  ($104.99 @ Newegg)
Video Card: Diamond Radeon R9 290 4GB Video Card (2-Way CrossFire)  ($259.99 @ Newegg)
Power Supply: EVGA 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $1135.87
Generated by PCPartPicker 2015-02-16 16:37 EST-0500
https://linustechtips.com/topic/311670-build-help/#findComment-4236429
